VW Club Corner
Local crank refinisher recommendation?
Topic: Local crank refinisher recommendation? (Read 3638 times)
jason_hamilton
Admin
1969 Karmann Ghia 2161cc
January 21, 2013, 06:01:49 PM »
Had a rod bearing fail on my crank and had to peel what was left of bearing off the journal. Need someone who can expertly assess the level of machining required and perform same. It's a balanced Berg 84mm with counterweights. Any favourites?
Jason Hamilton
Geoff
Re: Local crank refinisher recommendation?
January 21, 2013, 06:26:42 PM »
Give Dave at High Performance engines a call, Located just off Lougheed and Willingdon area.
Lunchbox
AirSpeed Forum Member
March 27, 2013, 02:29:50 PM »
wow those bearings are spun! I've seen it many times. Make sure that the crank isn't scored to far. I'd hate to say it but you may need a replacement crank.
Mike - 1980 VW RABBIT 1.8T Restoration
VW Club Corner
