Can anyone explain to me or point me in the right direction on how to delete the front hood handle so I just have the release inside my car? I've seen it on many cars but can't seem to find any info on how to go about it. Or if it's even a good idea for my build. If it's a simple list w cost mod then I'll probably add it to my list of to do's
If anyone else runs into this problem. Here is the update about my steering wheel issue. Part Number 12402 from Le Carra does not fit the Porsche 914 nor does the updated polished version 22402. Thats what their catalog lists for it and they have not up until now given me an explanation. I was able to return it back to Summit Racing they were really good about it but I can't find a fitting direct adaptor. the only other option would be to get a Momo hub adapter (which I Did) and a fitting MoMo wheel or other that has the same 6 bolt pattern (Which I did) or Le Carra also lists an adapter from the MoMo Hub to their steering Wheels. a route I didn't end up going.So with that I now am a proud owner of a nice fancy Leather steering wheel that does not fit. I'll list it for sale in the summer when I can bring it with me to Canada. I ended up ordering a OMP steering Wheel which I thought suited the car better now.can you buy a hub that fits the splines? I would think if you can fit the splines the rest you can make work with the use of a machine shopanything can be made to work it's just a matter of how much you want to play with itTo give a short Update. The Trany is now back together and soon on its way to Geoff. And I hope to have an update come Monday on what its looking like with my Engine build. I expect that my Car can go for Paint some time end of this month beginning of Feb. I have in the mean time done some work here and made door templates so i can start building the new door panels and rear 1/4 panels with a matching center console. Finally something I can start to do :-)
. He drilled and taped the shift fork cover for fluid take off to a cooler and temp sender ........ then if I find the temps are to high i can add a cooler....... with a VDO temp sender.
Dave your selector switched for your temp gauges, where did you find that? I've been looking on a few sites but haven't found a toggle other than a on-off-on so far. Otherwise I might just break down and stop by radio shack lol when I start the wiring this summer. Cheers René
