Technical => Electronics & Car Audio Forum => Topic started by: somevwguy on April 19, 2011, 01:22:12 PM
Are the alternator nuts and cupped spacers (or washer?) on the pulley end, the same for an alternator and a generator? thanks !!! PDT_Armataz_01_37
The nut and shim washers are the same.
And I think the cup spacer is too. Although I know there are 2 different heights. One is a couple mm taller.
thats not what i wanted to here! I'm having trouble getting my pulley on my alternator. I have a cup spacer off a generator, but when i try and put it on the alternator it sticks out to far and there are no threads to put the nut on? i'm guesing my afermarket pulley is thicker than s standard one? Does an aluminum pulley require a diffrent cup spacer? I guess this is the question I should of asked in the first place!!
this is the pulley I have?
http://www.cip1.ca/ProductDetails.asp?ProductCode=C13%2D33%2D1041
thanks!!! You_Rock_Emoticon
